DSM 1G/2G Vacuum Line Removal
Old Feb 1, 2008 | 08:35 AM
Default DSM 1G/2G Vacuum Line Removal
**This information should be used at your own descretion. Removal of these components may result in failure of the State Emmisions Standards**
All information was taken from Taboo Speed Shop
2g Eclipse/Talon
Normal Vacuum Diagram:
Stock emission controls and vacuum hoses configuration as found on federal 2g turbo DSM's
After removal:
The WGS, FPS, EGRS and EVAPS ports don't need to be plugged. However, leave them plugged in to prevent the ECU from throwing CEL and plug the port of the evaporative canister hose on the turbo inlet hose after you remove the canister. The boost gauge may be ran off the "P"port of the throttle body or the FPS line.
1g Eclipse/Talon
Stock emission controls and vacuum hoses configuration as found on federal 1g turbo DSM's
After removal:
The WGS, EPS and TVV ports don't need to be plugged. However, plug the port of the evaporative canister hose on the turbo inlet hose after you remove the canister (not shown). The boost gauge may be ran off the "P" port of the throttle body or the FPS line.
Taboo Speed Shop Links
1g:http://web.archive.org/web/200406211.../emissions.htm
2g:http://web.archive.org/web/200406221...emissions1.htm
mlahrens
Jan 29, 2016 06:54 AM
elboy0712
Feb 13, 2015 08:13 PM
PaulW52
Oct 31, 2013 09:13 AM
red123
Sep 19, 2010 10:56 AM
mitsunoobie
Apr 1, 2005 10:22 AM
