tps adjustment.
Old Oct 27, 2008 | 03:43 PM
needsagst98's Avatar
Default tps adjustment.
i know there is a thing in vfaq but one of my buddys has a diagnostic tool and he can read the voltage to adjust it because its off. i dont know the voltage it is supposed to be at does anyone know. i need to know soon. thank you. there was nohting about voltage in vfaq.
Old Oct 27, 2008 | 04:32 PM
Default RE: tps adjustment.
I got this off alldata
Turn the ignition switch ON (but do not start the engine).
Check the throttle position sensor output voltage. Standard value: 400-1,000 mV
If there is a deviation from the standard value, check the throttle position sensor and the related harness.
Switch OFF the ignition switch.
Old Oct 27, 2008 | 04:34 PM
i think its like .5 Volts
Old Oct 27, 2008 | 08:26 PM
silvercoupe97's Avatar
VFAQ has this to say...
http://www.plymouthlaser.com/tps.htm
and check out post #8 on Tuners...
http://www.dsmtuners.com/forums/prob...#post151648149
**if you have a logger, be sure that your TPS reads 10% open in the "closed" position.
MyLittleBlackBird
Dec 20, 2005 12:16 AM
monkey
Aug 27, 2005 03:07 AM
FARDJA
Jun 28, 2005 11:05 AM
MX6GT
Apr 8, 2005 06:15 PM
Vetter
Nov 22, 2004 10:44 AM
